Address 02: Auto Trans (0CW 300 044 T)
14:29:32
IDE80282-ENG114823 Clutch 1 Adaption basic charac. point 0 moment-Clutch 1 adaption basic characteristic point 0 torque 0.0 Nm
IDE80283-ENG114819 Clutch 1 Adaption basic charac. point 1 moment-Clutch 1 adaption basic characteristic point 1 torque 15.0 Nm
IDE80284-ENG114822 Clutch 1 Adaption basic charac. point 2 moment-Clutch 1 adaption basic characteristic point 2 torque 149.5 Nm
IDE80285-ENG114815 Clutch 1 Adaption basic charac. point 3 moment-Clutch 1 adaption basic characteristic point 3 torque 220.0 Nm
IDE80286-ENG127831 Clutch 1 Adaption clutch end position closed-Clutch 1 adaption upper stop closed 26.6 mm
IDE80287-ENG127832 Clutch 1 Friction value correction factor-Clutch 1 frictional correction factor 99.9 %
IDE80288-ENG114818 Clutch 1 Characteristic line shift-Clutch 1 characteristic shift 0.00 mm
IDE80289-ENG114806 Clutch 2 Adaption basic charac. point 0 moment-Clutch 2 adaption basic characteristic point 0 torque 0.0 Nm
IDE80290-ENG114810 Clutch 2 Adaption basic charac. point 1 moment-Clutch 2 adaption basic characteristic point 1 torque 15.0 Nm
IDE80291-ENG114821 Clutch 2 Adaption basic charac. point 2 moment-Clutch 2 adaption basic characteristic point 2 torque 128.5 Nm
IDE80292-ENG114809 Clutch 2 Adaption basic charac. point 3 moment-Clutch 2 adaption basic characteristic point 3 torque 220.0 Nm
IDE80293-ENG127861 Clutch 2 Adaption clutch end position closed-Clutch 2 adaption upper stop closed 22.9 mm
14:29:32
IDE06283-ENG120908 Clutch 2: adaptation: clutch end position closed (mm)-Clutch_2_adaption_upper_stop_closed_mm 24.8 mm
IDE06284-ENG120907 Clutch 2: adaptation: clutch end position open (mm)-Clutch_2_adaption_upper_stop_open_mm 2.1 mm
IDE06285-ENG120911 Clutch 1 adaptation basic characteristics point 0 position (mm)-Clutch_1_adaption_basic_characteristic_point_0_mm 10.0 mm
IDE06286-ENG120912 Clutch 1 adaptation basic characteristics point 1 position (mm)-Clutch_1_adaption_basic_characteristic_point_1_mm 11.3 mm
IDE06287-ENG120906 Clutch 1 adaptation basic characteristics point 3 position (mm)-Clutch_1_adaption_basic_characteristic_point_3_mm 22.6 mm
IDE06288-ENG120899 Clutch 2 adaptation basic characteristics point 0 position (mm)-Clutch_2_adaption_basic_characteristic_point_0_mm 9.1 mm
IDE06289-ENG120900 Clutch 2 adaptation basic characteristics point 1 position (mm)-Clutch_2_adaption_basic_characteristic_point_1_mm 11.9 mm
IDE06290-ENG120902 Clutch 2 adaptation basic characteristics point 2 position (mm)-Clutch_2_adaption_basic_characteristic_point_2_mm 18.8 mm
IDE06291-ENG120901 Clutch 2 adaptation basic characteristics point 3 position (mm)-Clutch_2_adaption_basic_characteristic_point_3_mm 23.0 mm
IDE06292-ENG120903 Clutch 1: adaptation: clutch end position open (mm)-Clutch_1_adaption_upper_stop_open_mm 1.5 mm
IDE06293-ENG120904 Clutch 1: adaptation: clutch end position closed (mm)-Clutch_1_adaption_upper_stop_closed_mm 26.9 mm
IDE06294-ENG120905 Clutch 1 adaptation basic characteristics point 2 position (mm)-Clutch_1_adaption_basic_characteristic_point_2_mm 17.8 mm
Hoop dat jullie er iets mee kunnen!
Een bekende heeft dit middels VCDS zo uitgelezen.
Geen idee hoe hij dit precies gedaan heeft, want ik heb er verder weinig verstand van!
Kan t ff niet vinden
