Vandaag alles in orde gekregen eindelijk wel nog 2 fouten die blijven en denk dat ze enkel weg zullen gaan met ander hardware
Saturday,11,June,2022,14:49:41:15437
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: TMBCS21Z572147252 License Plate:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 76
VIN: TMBCS21Z572147252 Mileage: 247330km-153683miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 LB HW: 03G 906 021 AN
Component: R4 1,9L EDC 000SG 9251
Revision: --H06--- Serial number: SKZ7Z0G4183103
Coding: 0000071
Shop #: WSC 73430 790 00000
VCID: 6A8DCC77C07C2D8B71B-803E
VINID: 91D4938C206A14708110708508FAD569B7
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3FDB4D23EB7E7823F65-806A
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Z0 907 044 M HW: 1Z0 907 044 M
Component: ClimatronicPQ35 110 0400
Revision: 00110021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 40D94EDF968007DB8FF-8014
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004841406
Coding: F1000A110000100040110D330000830000590105640000
Shop #: WSC 00046 123 12345
VCID: 6C81CA6FCA8833BB037-8038
Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 030407 022 0601
Coding: 00057271
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 030407 020 0105
Coding: 00471077
Shop #: WSC 00046
1 Fault Found:
00926 - Terminal 30
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 52
Mileage: 247334 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 5.00 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q2 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD14UML+
Coding: 0020786
VCID: 3D27372BE1726A33E49-8068
Subsystem 1 - Serial number: 6332MSME19285D7FV
Subsystem 2 - Serial number: 6342MSME194B0923B
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Lenksäulenmodul 036 0070
Coding: 0000012
VCID: 00598EDFD600C7DBCFF-8054
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 812 D HW: 1Z0 920 812 D
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0G4183103
Coding: 0002101
Shop #: WSC 11111 111 11111
VCID: 35372F0BD942B2732C9-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 070407F1000032
Coding: 3D0F074007001302
Shop #: WSC 73430 790 12345
VCID: 2F3B1D633B1E88A3665-807A
1 Fault Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 11
Reset counter: 52
Mileage: 247334 km
Time Indication: 0
Date: 2000.00.00
Time: 11:28:53
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1610
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0953
Coding: 0000116
VCID: 3829263FCE504F1B37F-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.068 H07 1806
Shop #: WSC 73430 790 90108
VCID: 3431120FD238AB7B1B7-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 98D002007F2D8F0FC8CB000004CC
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000116
VCID: 392F233BF55A5613C81-806C
Address 56: Radio Labels:
VCID: 55F78F8B7C029273CC9-FFFE
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 C HW: 1Z0 919 283 C
Component: Parkhilfe 8-Kan H04 0020
Coding: 0000001
VCID: 3E253027EC74712BFD3-806A
End----------(Elapsed Time: 01:10, VBatt start/end: 12.6V/12.6V)-----------
