Hallo,
Voor de Fabia van mij zus ben ik op zoek naar het onderdeel nummer van de lambda sonde.
Kan iemand mij hieraan helpen?
Hieronder de log van vcds :
2 Faults Found:
17141 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 00 [096] - Malfunction / Open Circuit
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 35375 km
Date: 2019.01.13
Time: 19:59:05
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 93 C
Intake air temperature: 33 C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.133 V
Unlearning counter according OBD: 39
Engine torque: 0.0 Nm
Time since ignition off: 109 s
Irregular shutdown of the counter control mod-Bits 0-7: 0
Current system status: SYC_DRIVE
Current system status-Test_Program_Exe Con State 02 UBYTE: 4
15356 - Oxygen (Lambda) Sensor Signal B1 S2
P2270 00 [237] - too Lean
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 34932 km
Date: 2019.01.03
Time: 16:45:45
Engine speed: 2818.50 /min
Normed load value: 45.1 %
Vehicle speed: 84 km/h
Coolant temperature: 86 C
Intake air temperature: 26 C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 14.936 V
Unlearning counter according OBD: 40
Mass flow through throttle valve: 46.4 kg/h
Readiness: 0000 0001
Alvast bedankte voor jullie inbreng.
Verstuurd vanaf mijn SM-N950F met Tapatalk
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 35375 km
Date: 2019.01.13
Time: 19:59:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 34932 km
Date: 2019.01.03
Time: 16:45:45
