Lambda sonde
Hallo,
Voor de Fabia van mij zus ben ik op zoek naar het onderdeel nummer van de lambda sonde.
Kan iemand mij hieraan helpen?
Hieronder de log van vcds :
2 Faults Found:
17141 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 00 [096] - Malfunction / Open Circuit
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 35375 km
Date: 2019.01.13
Time: 19:59:05
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 93 C
Intake air temperature: 33 C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.133 V
Unlearning counter according OBD: 39
Engine torque: 0.0 Nm
Time since ignition off: 109 s
Irregular shutdown of the counter control mod-Bits 0-7: 0
Current system status: SYC_DRIVE
Current system status-Test_Program_Exe Con State 02 UBYTE: 4
15356 - Oxygen (Lambda) Sensor Signal B1 S2
P2270 00 [237] - too Lean
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 34932 km
Date: 2019.01.03
Time: 16:45:45
Engine speed: 2818.50 /min
Normed load value: 45.1 %
Vehicle speed: 84 km/h
Coolant temperature: 86 C
Intake air temperature: 26 C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 14.936 V
Unlearning counter according OBD: 40
Mass flow through throttle valve: 46.4 kg/h
Readiness: 0000 0001
Alvast bedankte voor jullie inbreng.
Verstuurd vanaf mijn SM-N950F met Tapatalk
