rad3d
Kan het zijn dat door te hoge toeren deze melding is ontstaan ? De vrouw had beetje misgeschakeld.
Ergens is de EPC en Motor lampje gaan branden.
Vagcom fault-codes;
Controller: 047 906 033 C
Component: 1,4l SIMOS3PA G00HSSJ4C
Coding: 00061
Shop #: WSC 13765
TMBNB46Y123539071 SKZ7Z0B1439005
3 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17549 - Load Calculation Cross Check: Implausible Value
P1141 - 35-10 - - - Intermittent
16712 - Knock Sensor 1 (G61): Signal too High
P0328 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 08 -------------------------------------------------------
Controller: 6Y0 820 045
Component: Klimaanlage X0830
1 Fault Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
29-10 - Short to Ground - Intermittent
Vagcom fault-codes;
Coding: 00061
Shop #: WSC 13765
3 Faults Found:
1 Fault Found:
