Gateway The Gateway (aka. Diagnostic Interface for Databus OR CAN-Gateway) is responsible for passing Messages from one Control Module to another, older versions of the Gateways were not compatible and wouldn't allow a Diagnostic Tool like VCDS to communicate with the new Radio Navigation System.
Address 19: CAN Gateway Labels: 1K0-907-530.lblPart No SW:
1K0 907 530 Q HW: 1K0 907 951 Component: J533__Gateway H16 0202 In this Example the Software Part Number is 1K0-907-530-Q, only Gateways with this Part Number (or newer) are known to be compatible with the RNS310. For the VW Passat (3C) only Gateways with the Part Number 3C0-907-530-E (or newer) are known to be compatible.
Installation & Wiring
Additional Information can be found in the Repair Manuals, the Wiring Diagrams, the Parts Catalog and/or the Instructions included in the Retrofitting Kit.
Configuration
The following Activations are necessary to ensure that the newly fitted parts are properly recognized and are ready to use.
- Update the Installation List in the Gateway (J533 / #19).
- Register the newly added 37 - Navigation Control Module, in case you had a Navigation System installed before the Retrofit this step may not be necessary. Address 56 - Radio should also be activated in case there was no Radio installed prior to the Retrofit. Even though Address 56 - Radio is registered, the RNS310 will NOT communicate via that Address - you have to use 37 - Navigation instead.
