Mr. Horizon
Ik heb inmiddels de volgende stappen al doorlopen, maar helaas. Nog andere suggesties hier misschien?
This is a common issue with the Garmin "Move & Fun" portable infotainment system found in the 2013 Skoda Citigo. Since you can hear them but they cannot hear you, the Bluetooth audio "output" (your speakers) is working, but the "input" (your microphone) is failing.
Here are the possible reasons and troubleshooting steps, ordered from the easiest to the most likely technical faults.
1. Dirty Connection Pins (Most Common Cause)
The Garmin unit is removable and connects to the car via a specialized mount on the dashboard. If the copper contact pins on the bottom of the device or the mount are dirty or oxidized, the microphone signal (which travels through these pins) can get cut off while the speaker audio remains.- The Fix: Remove the Garmin unit from the dashboard arm. Use a soft cloth with a little rubbing alcohol (or electronic contact cleaner) to clean the gold pins on the bottom of the device and the corresponding pins on the holder. Snap it back in firmly.
2. Microphone Volume Settings
The Garmin system has an internal setting for microphone sensitivity which may have been turned down or muted.- The Fix:
- Go to the Phone menu on the Garmin screen.
- Look for Settings or Audio options within the phone menu.
- Check for a Microphone Level or Mic Volume slider and ensure it is not set to the bottom/mute.
3. Phone Bluetooth Permissions
Modern smartphones (iPhone and Android) have privacy settings that sometimes block access to the microphone for specific devices, or they may be routing the audio incorrectly.- The Fix (iPhone): Go to Settings > Bluetooth > Click the "i" next to your Skoda/Garmin device > Ensure "Device Type" is set to "Car Stereo" (if available).
- The Fix (Android): Go to Settings > Bluetooth > Tap the gear icon next to the Skoda device > Ensure "Phone calls" and "Input device" are toggled ON.
- During a call: Look at your phone screen while calling. Tap the "Audio" or "Speaker" icon and ensure "Skoda/Garmin" is selected, not "iPhone" or "Speakerphone."
4. The "Internal Mic" vs. "External Mic" Confusion
The 2014 Citigo system is unique because the Garmin unit is the brain, but it sometimes relies on the car's speakers. However, the microphone is usually located on the Garmin unit itself (a small pinhole on the front casing), not in the car's roof liner like in larger Skodas.- The Fix: Ensure nothing is blocking the small microphone hole on the front of the Garmin screen. If you have put a decorative cover or a phone holder in front of the Garmin unit, you might be blocking your voice.
5. System Glitch (Requires Hard Reset)
The software on these 2014 units is quite old and can freeze the audio input driver.- The Fix: Perform a "Soft Reset."
- With the device turned on, press and hold the Power button (on top of the unit) for about 10-15 seconds until the screen goes black and reboots.
- Note: This will not delete your saved maps or home address.
