Op een Engels forum gevonden:
Laat even weten of dit werkt, ben namelijk wel benieuwd of ik een 2e remote in zou kunnen leren op die manier..
you need VCDS. Select > 18 - Aux. Heater > Basic Settings - 04 > Remote Matching > Follow the steps on the screen.
Remote Control Adaptation for 18-Aux. Heat
Prerequisites:
- Vehicle must have J364-Auxiliary Heater with R149-remote control receiver.
- Auxiliary heater must be 'off', remote adaptation will NOT work if on.
- Voltage of battery and the telestart sensor are okay.
- Coding has to support the remote control functions.
Note: A total of three remote can be adapted and each new additional remote adapted will overwrite the oldest adapted remote.
[Select]
[18 - Aux. Heater]
[Adaptation-10]
Read channel [005]
[Test] and [Save] a new value of [0]
Press Remote's [Off] button for 1 second
The value should change from [0] to [1]
The fields should show the status of the procedure.
(the number of the remote) and (learned / not learned)
[Done, Go Back]
[Close Controller, Go Back - 06]
