Misschien heb je hier wat aan. Je kunt denk ik snel ontdekken welke versie je hebt.
Kan best zijn dat er nog veel meer versies zijn.
Vergeet niet vooraf een foto te maken!
Engine compartment (version 1)
Under-hood fuse box diagram (ver.1): Skoda Superb (2012, 2013, 2014, 2015)
Fuse assignment in engine compartment (version 1, 2012-2015)
No.    Power consumer
1    Front right main headlight, right tail light
2    Valves for ABS
3-4    Not assigned
5    Horn
6-12    Not assigned
13    Control unit for automatic gearbox
14    Not assigned
15    Coolant pump
16    Not assigned
17    Instrument cluster, windscreen wiper lever, and turn signal lever
18    Audio amplifier (sound system)
19    Radio
20-22    Not assigned
23    Engine control unit
24    Data bus control unit
25-26    Not assigned
27    Fuel dosage valve
28    Engine control unit
29    Main relay
30    Auxiliary heating and ventilation control unit
31    Windscreen wipers
32-37    Not assigned
38    Radiator fan, valves
39    Clutch/brake pad sensor
40    Lambda probe
41    AKF valve
42    Lambda probe
43    Ignition
44-46    Not assigned
47    Front left main headlight, left tail light
48    Pump for ABS
49    Power supply for terminal 15 (ignition on)
50-51    Not assigned
52    Power supply relay - terminal X
53    Accessories / Power to the internal fuse carrier
54    Not assigned
Engine compartment (version 2)
Under-hood fuse box diagram (ver.2): Skoda Superb (2012, 2013, 2014, 2015)
Fuse assignment in engine compartment (version 2, 2012-2015)
No.    Power consumer
1    Not assigned
2    Control unit for automatic gearbox DSG
3    Measuring circuit
4    Valves for ABS
5    Control unit for automatic gearbox DSG
6    Not assigned
7    Power supply relay - terminal X
8    Radio
9    Not assigned
10    Engine control unit, Main relay
11    Auxiliary heating and ventilation control unit
12    Data bus control unit
13    Engine control unit
14    Ignition
15    Lambda probe (petrol engine), glow plug system relay and fuel pump (diesel engine)
16    Front right main headlight, right tail light
17    Horn
19    Windscreen wipers
20    Valve for metering fuel, coolant pump, high pressure pump
21    Lambda probe
22    Clutch pedal switch
23    Coil of the coolant pump relay valves, high-pressure pump
24    Radiator fan
25    Pump for ABS
26    Front left main headlight, left tail light
27    Control unit for glow plug system
28    Windscreen heater
29    Accessories / Power to the internal fuse carrier
30    Power supply for terminal 15 (ignition on)
