Mistraller
Review van dat artikel zegt genoeg:
The device works with VAG K+CAN Commander 1.4 only. It WILL NOT work with VAG Tacho, VAG-COM and other diagnostic software.
Software is supplied on the small CD, so I was unable to read it from my laptop which has slot-loadable DVD drive.
VAG K+CAN Commander 1.4 is very old and many functions are not implemented (e.g. actuator test). Newer versions are available to the owners of the original Abritus72 hardware only (this dongle is NOT the original hardware And I couldn't find any other versions of the software which work with this dongle.
Other Thoughts: The software has a little bit too technical interface, so it's easy to do something really bad to your car unless you know what you're doing.
